Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
NEW BIOS: DZ77GA-70K, DZ77RE-75K (Standard BIOS) GAZ7711H.86A.0053.2012.0905.2145 Production BIOS
Post your thoughts!
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=3442&DwnldID=21844&lang=eng&iid=dc_rss http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=3442&DwnldID=21844&lang=eng&iid=dc_rss
BIOS Update Release Notes
PRODUCTS: DZ77GA-70K, DZ77RE-75K (Standard BIOS)
PRODUCTS: DZ77GA (Gasper) GAZ7711H.86A.0053.2012.0905.2145 Production BIOS
About This Release:
· Date: Sept 5, 2012
  • ME Firmware: 8.0.13.1502
  • Integrated Graphics Option ROM: Build 2132
  • SATA RAID Option ROM: v11.2.0.1527
  • LAN Option ROM: v1.3.81 PXE 2.1 Build 091
New Fixes/Features:
  • Update RAID OPROM to v11.2.0.1527.
  • Update ICBD module
  • Fixed Linux UEFI Problem.
  • Fixed TBT Hot Plug issue to change TbtSmm.c.
  • Fixed BEL issues as below items
  • [Flash Update Testing] Flash Update Status Indicators
  • [Flash Update Testing] Power Button Recovery
  • [Setup & Post] Power Button Menu
  • [PCI] PCI Express ACPI Table
  • [BIOS Passwords] User Access Level = Full
  • [BIOS Passwords] User Access Level = Limited
  • [BIOS Boot Order] Boot USB Devices First
  • Improved UEFI boot option with Advanced boot order style.
  • Win8 Support function.
  • Changed PCH GPIO_029 to Native mode.
  • Added \OEMEM\OptionRoms\bios.bin to replace Marvell AHCI option ROM.
  • Updated code for PS/2 device enable/disable function.
  • Changed STD LED function for Win8 request.
  • Updated ICBD Module, 4.6.5.3_ICBD_ITK5_050 with Visual BIOS 1.0.8.
  • Updated code for flash BIO file.(F7)
  • Remove Serial port support.
Community Manager
1) POST still take long time to complete, 2-3 minutes to complete POST before booting into OS. Disable Marvell chipset seems to reduce POST duration.
2) Seems fixed the addon controller card issue but not entirely.
Here's some setup I tested:
addon controller card - INT13 enabled
intel raid - enabled
eSATA device plugged in
Result: Hang
eSATA device disconnected
Result: Passed
addon controller card - INT13 disabled
Result: Passed
