Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Need Help on DZ68BC Bios Update ?
Completed a new build and i can only assume the new DZ68BC MB will have an earlier Bios version versus the latest 0027. My question is should i update the Bios to 0027 1st thing after the initial boot and if yes will the 0027 Bios update have to be on a cd disc or will the pc read it from a usb 2.0 flash drive i have it stored to along with all the other pertinent latest drivers i will need after the initial Win 7 install ?
I know i can update it later but if done later will the 0027 update set the Bios back to the Default settings ?
Sorry for probably silly questions but i just want to make sure i follow proper Intel procedures for this DZ68BC MB
Regards & Thanks for any replys, Ron
Highlighted
Valued Contributor I
Re: Need Help on DZ68BC Bios Update ?
Hi Ron - The link will take you to Intel's recommended procedure for updating after initial boot. http://www.intel.com/support/motherboards/desktop/sb/CS-031891.htm?wapkw=(driver+installation+order) http://www.intel.com/support/motherboards/desktop/sb/CS-031891.htm?wapkw=(driver+installation+order) . I would recommend completing these updates and then update the BIOS. The express method of updating , http://www.intel.com/support/motherboards/desktop/sb/CS-023357.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023357.htm , works well. Note any changes you have made to default settings before the update and then, afterwards, enter the BIOS to ensure the update did not change your settings. Regards. Peter
Highlighted
Thank You very much for the info with links.
Although i will be performing the initial boot with a single discrete Nvidia 560ti video card i also assume i should in the Bios " Under Configuration -> Video, set the Integrated Graphics Device option to " Always ENABLE " in case later i install the Lucid Virtu software. Is that correct even though i plan on always using the discrete Nvidia 560ti video card ?
Sorry i forgot to ask this additional question in my 1st post.
Highlighted
Ron - I can not answer your question directly. I have found the info at this link helpful in the past. http://download.intel.com/support/motherboards/desktop/sb/biosglossarybymenu_v17.pdf http://download.intel.com/support/motherboards/desktop/sb/biosglossarybymenu_v17.pdf . Hope that helps.
Highlighted
New Contributor II
Ron --
I just completed a build with DZ68BC and 560ti a couple weeks ago.
I recommend updating the BIOS to 0027 "first thing" -- before installing OS. Put the 0027 bios file on a USB flash drive and use the "F7" at boot to update BIOS. Afterwards, check settings -- some of mine were cleared by the BIOS update (most notably, I had set RAID and after BIOS updated it was back to AHCI).
As for video... I initially set my system up with just the onboard video, then installed the 560ti later. Yes, you need to set integrated video to "Always on" if you intend to use Lucid. Also set video "priority" for the adapter to which you will be attaching your monitor -- typically this would be the PCI video card.
Hope that helps.
Highlighted
New Contributor II
Yes, I would agree with "first thing" (the list at an earlier link doesn't even mention BIOS, since it's implied that it's already done) because the Windows installation can potentially benefit.
As for updating it subsequently, should the need ever arise, I've read here that you might want to remove the video card to do it, but practically speaking, I would hope that merely switching to internal video would be enough.
Highlighted
Alan, Thanks for the info. I will do as you suggest and immediately during initial 1st boot tap F7 and insert my USB flash drive which already contains the latest 0027 express Bios update on it. I just didnt know if the PC would be recognizing the USB 2.0 ports on initial boot to install the express bios update method versus the flash method from a bootable USB device.
Dont know for sure if i will be later on installing the Lucid Virtu software since some folks claim it reduces the performance of your discrete GPU video card slightly. I plan on running from either the 560ti DVI or its mini Hdmi output to the existing Asus VW246H Hdmi monitor.
Regards & Thanks again for all the help from ou fine folks !
Ron
Highlighted
New Contributor II
Actually, by "first thing" -- I mean before loading OS. Doesn 't necessarily need to be done at first power-on.
At first power-on, I'd use F2 to go into BIOS and "look around" -- good time to check that your drives and cards are recognized, and familiarize yourself with the BIOS menu structure and options, and look to see that CPU temp and fans are all working. Once you know the board "works", shut it down and put in your flash drive with bios file, then power-up and use F7 to load the new BIOS.
As "rseiler" said, the update can affect OS so best to do it before OS installation. Also, any custom settings may be lost when updating, so might as well do the update first and then change the settings, otherwise you have to go through all the settings twice!
I would also recommend testing memory before loading OS. If you have memory that supports XMP, go to the BIOS "Performance" menu and change it to XMP memory, reboot and make sure memory is running at expected speed/timings. Then (whether or not you have XMP), boot to a MEMTEST86 disk and let the test run through at least one full cycle.
Bad memory can cause all kinds of wierd, intermittent problems later -- so best to check it before you start the OS loading!
Highlighted
Alan i got your sequence steps down now. I do have the 4 x 4GB of Corsair Vengeance below so all the slots are filled and i planned on setting to XMP:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233198 http://www.newegg.com/Product/Product.aspx?Item=N82E16820233198
I plan on firing it up tomorrow so hopefully all will go fairly smooth.
Regards, Ron
Highlighted
New Contributor II
Ron,
LOL - We must shop together. DZ68BC, 560ti, and now Corsair Vengeance 16gb w/ low profile heat spreaders. Same stuff here. At least I can tell you it all works well together smoothly! 🙂
Highlighted
Hi - You are correct that the list does not mention BIOS but I do not think it is because of an implication that it is already done. In a number of articles in the Support section of this site, Intel recommends you only update the BIOS when it will correct a problem that you are experiencing. I do not agree with this philosophy but updating the BIOS prior to first boot does add another variable (potential problem) that does not have to be introduced at this step. Just my two-cents worth. Regards. Peter
Highlighted
New Contributor II
Out-of-the-box though has to be an exception. In those cases, we're a couple pages worth of revision notes out of date. I think fixing (and in some cases, updating) all that far outweighs the slim chance of a BIOS failure. Also, if you're going to be exceptionally unlucky, what better time?
Highlighted
New Contributor II
My board arrived with 0021. One quick look at 0027 release notes and I saw it fixed a problem between RAID and Fast Boot, which were both features that I intended to use. Further reading of release notes for 0026, 0025, 0024, 0023, and 0022... Well, let's just say there were a LOT of updates/fixes there, and it would be hard to imagine anybody that would be unaffected by ALL of them.
I knew I eventually would want to load the 0027 release, so figured it was best to do so right away. My 30-day return clock was ticking, so if the board wasn't going to work right with 0027 I wanted to know right up front!
YMMV.
Highlighted
Highlighted
Peter, the PDF regarding the Lucid Virtu technology was included in a document letter inside the retail DZ68BC box. I plan on running in D mode using the Nvidia 560ti as my primary but will set the Integrated Graphics to " Always ON " in the bios just in case later i decide to install its latest graphic drivers and the Virtu software but only after i have updated to the 0027 latest Bios.
I built this rig to provide primarily video editing and very little gaming if any. Like Alan i was going to install at least a 120gb SSD along with the 1.5TB WD caviar black but i still have no faith with any of the SSD drives. The new Intel 520 series might prove to be reliable with resolved Sandforce issues but the consumer cost is IMO still too high.
Regards, Ron
Highlighted
One final question before i perform initial boot.
If i intend to update initially to the 0027 Flash Bios zip file using the F7 key flash method from a USB thumb drive should i remove the Nvidia 560ti board and use only the integrated graphics from the DZ68BC during the Bios flash update procedure. Will this ensure the least possible conflicts ?
Alternatively if i choose to update to the latest 0027 Bios AFTER the Windows 7 install using the Express Bios update method will leaving the Nvidia 560ti video card as the primary be O.K. or should the user ALWAYS only update the Bios using the Integrated Graphics with an Intel board ?
Regards, Ron
Highlighted
New Contributor II
Ron,
I honestly can't say whether having the 560ti in the machine when updating BIOS would have any effect. I highly doubt it would cause any problem. But I have seen others here on the forums who disagree with that, and advise removing discrete video cards before flashing.
My personal experience... I built the system, flashed to 0027, installed Win7, and ran the Express Installer -- all using only the Integrated Graphics. After all that was working, I installed the 560ti, went to BIOS and set integrated to "Always on" and primary to the PCIE card, booted to Windows, installed latest Nvidia drivers, then installed Virtu. So I can say for sure THAT sequence works. I suspect it would also work just fine with the 560ti in from the beginning, but I didn't do it that way so cannot say for sure.
I will warn you... The initial few screens of Windows7 setup are difficult when using the Integrated Graphics. The Win7 x64 SP1 disk apparently doesn't understand the Integrated Graphics adapter (no driver for it), so you get a really ugly 4-color low-res experience. Things don't even highlight correctly, so you can't always see where the mouse pointer is, or what you are clicking. All that gets fixed when you run the "Intel Express Installer" CD (first step after completing Windows Setup), as it loads the Intel HD Graphics driver. But up until that point, it's pretty painful.
...Alan
Highlighted
Thanks Alan,
Regards, Ron
Highlighted
New Contributor II
On that last paragraph, very strange, since on an integrated graphics-only install here with the same OS, I didn't see anything out of the ordinary.
Highlighted
New Contributor II
Interesting...
I suppose the monitor could have been involved, although it was correctly recognized by Windows (NEC LCD1515). I tried various settings for color depth / resolution, rebooting, etc., but to no avail -- it looked hideous (4 or 8 color, "blotchy") in every combination. But I managed to get through the Windows setup (really not that many dialogs) with it that way.
As soon as I loaded the Intel HD Graphics driver using the Intel Express Installer disk, the next logon screen came up with 1024x768x32, crystal clear and looking great. So I *concluded* it was lack of driver support for the Integrated graphics on Windows7 disk, but there could certainly be something else in the mix.
I subsequently installed a GeForce 560ti 2048mb. It worked great with both the NEC LCD1515 and my primary Dell 2408WFP, even with the default nVidia drivers included with Windows7.
