Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Need help status-checking warranty of intel motherboard
bkm
hi all, i want to status-check the warranty of my intel board DG31GL. On this web page http://www.intel.com/p/en_US/support/warranty/statuscheck Check warranty for an Intel product they are asking Serial No: and Stocking Id/Part No:. I have entered my serial number BTGL83600AU7 correctly.. The only other number i have is an AA number AA E33912-200. Is it the Stocking Id/Part No? If so how will you enter it. I have tried different combinations like AAE33912-200, E33912-200, E33912200 etc of which none is working. Thanks
bkm
solved the issue myself. give BTGL83600AU7 as serial number and E33912-200 as Stocking Id/Part No and if the server is NOT BUSY or NOT DOWN ,will get warranty status..
