Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Need help with Wake-on-LAN. DH67BL Mainboard, Windows 10, 82579V onboard NIC
Earl_in_Ohio
I have enabled WOL in the BIOS, and made sure that the "allow this adapter to wake the system" is also checked, but the system does not wake as expected. The driver information shows that the NIC is using a Microsoft driver (12.17.10.8) , not Intel. Could this be the problem? Is there an Intel driver I should be using? If yes, how do I get it and install it? Should I be looking elsewhere for a solution?
Many thanks.
Earl
