Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Network cable unplugged Acquiring network address
VSing11
I have Windows XP professional SP2. Despite installing Lan card drivers (LAN_allXP_5.774_PV_RTL) for intel board D945GCNL I am getting message "network cable unplugged, acquiring network address" but when I go to QoS packet scheduler and select speed and duplex 100 mbps nothing happens but when I select 10 mbps my internet get connected but the problem is that i get very slow download speed. Please guy help me out so that I get internet without going through this QoS process. My processor is core2duo E7200. I lost CD of motherboard.
Another problem is whenever i start my PC i get message This wizard helps you install software for: "Microsoft UAA Bus Driver for High Definition Audio" . I do no have CD so please let me know from where I will will get the driver?
My email ID
Please help me Thanks in advance
AlHill
None of your equipment is supported, and Windows XP has not been supported since April 2014.
Forget the CD. All the drivers you need can be found here: https://ark.intel.com/products/50369/Intel-Desktop-Board-D945GCNL Intel® Desktop Board D945GCNL Product Specifications . Just click on downloads and software.
And, assuming your upstream equipment (switches, router, etc) is good, your motherboard, or your LAN adapter, possibly are failing.
Time to upgrade your hardware and get off of XP.
Also, I have removed your email address to protect your privacy.
Doc
