Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
No POST with DQ77KB
APa
I have a problem with my new DQ77KB. There is no POST, no beep and the screen (via HDMI) stays empty.
CPU is a i5-3470s, which should work with this mainboard.
What can I do to fix this issue?
Thank you!
KL2
Valued Contributor I
Similar problem: /message/178179 https://communities.intel.com/message/178179
Latest BIOS here: https://downloadcenter.intel.com/download/25261/BIOS-Update-KBQ7710H-86A- https://downloadcenter.intel.com/download/25261/BIOS-Update-KBQ7710H-86A-
Other than that, make sure your power supply is the correct voltage for the mainboard.
Also, you could try unplugging both the PC and the monitor from the wall, waiting 20-30 seconds, then plug them back in and start up. Every once in awhile, digital connections have some bad hair days when trying to communicate.
Lastly, you could try disconnecting the motherboard from power (make sure the standby LED is off), and remove all RAM, connect the power back to the mainboard and start it up. You should have some memory beeps (three), and that will at least let you know your board is semi-OK. I don't see a PC speaker on that mainboard, so I suppose it's routed through the 3.5" green line out header.
APa
Thank you. It is the same issue as here described:
Power supply ist the correct voltage -> 19 V (180 Watt)
CPU fan is rotating, power LED is on but there is no POST. Is it possible to make a BIOS update despite the fact that there is no POST?
I disconnected the motherboard from power an removed RAM. I started the computer up and I heard signals, which told me that there is a RAM issue.
I will try the 20-30 seconds unplugging test.
EDIT: Display cable test did not help. When I plug an USB stick to the motherboard it remains without light.
KL2
It should beep if there is no RAM present, that's a good thing. Maybe try a different piece of RAM that is compatible with that mainboard?
So, do your keyboard lights show up (Num Lock, Caps Lock, etc.)?
You may not be seeing the POST sequence, since the problem may be strictly a video output one -- there is some chatter in the BIOS release notes relating to that: https://downloadmirror.intel.com/25261/eng/KB_0058_ReleaseNotes.pdf https://downloadmirror.intel.com/25261/eng/KB_0058_ReleaseNotes.pdf
If you have a hard drive that has Windows or something on it, attach it to the mainboard, it would also be handy if you could plug in an LED into the HDD LED header on the mainboard. Start it up and see if the LED blinks (HDD access), or if you can hear the HDD chattering after 20 or so seconds (however long it takes for the board to attempt to boot from it).
Assuming you have HDD access (boot), you can assume the board is functional, and your problem is strictly video, and possibly solved by BIOS upgrade.
You have to recover the BIOS like this: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html
The big caveat with that is, since you have no video output, you will not see any of the messages that tell you when it's safe to shut down. If you attempt a BIOS recovery with no video, I'd wait 10-15 minutes or so before shutting the computer down. Half-done BIOS updates are a sure way to brick a mainboard.
APa
Thank you.
You are right. The motherboard beeps three times when RAM is removed. I tried other Ram units, but still I have the same problem.
When I plug a keyboard to the motherboard, there are nor lights. Num Lock, Caps Lock do not show up lights.
Also I installed another HDD but the same issue remains. I can hear that HDD does not load Windows.
KL2
Sounds pretty funky.
What's the AA number on the board? http://www.intel.com/content/www/us/en/support/boards-and-kits/000005624.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005624.html
Even when it's powered on, and you hit Num Lock, the keyboard light for it doesn't come on?
There are no bent pins in the processor socket?
The motherboard is properly grounded? (*not* sitting on an anti-static bag).
The power supply you're using is an external one?
If you have a USB flash drive with an activity LED on it, you could try the USB BIOS recovery procedure *without* adding the BIOS file to the flash drive. That way, there's no harm no foul on checking each USB port for activity. If the USB flash drive access LED lights, you should be good to go for a BIOS recovery.
KL2
Also, if you move the BIOS configuration jumper one spot over to 'configure', does anything happen after it's turned on?
Move the jumper when the motherboard is off as well.
APa
The AA number is G81483-501.
When it is powered on and I hit Num Lock the keyboard light does not come on.
There are no bent pins in the socket.
Yes, it is properly grounded.
The power supply I am using is an external one.
When I plug an USB flash drive to the motherboard the light of the USB flash drive does not come on, too. I also tried to "make" recovery procedure with an empty USB flash drive. The issue still remains.
Nothing happens, when I move the BIOS configuration jumper one spot over. Still the same problem. No beep, no POST, empty screen, power LED is on the whole time, CPU fan is rotating, when the board is powered on.
KL2
You could try removing the CMOS battery for 10-20 minutes if you haven't already.
G81483-501 comes with BIOS 0051 by default according to this: http://qdms.intel.com/dm/i.aspx/FC9E4181-F673-402A-9583-2385DE8A64FC/PCN112376-00.pdf http://qdms.intel.com/dm/i.aspx/FC9E4181-F673-402A-9583-2385DE8A64FC/PCN112376-00.pdf So, that BIOS definitely supports your CPU, haha.
I guess at this point, the only thing I find strange is that you get RAM beeps without RAM installed. What are the model / part # 's of the RAM you've tested?
Other than that, you're pretty much at the point where unless you have a different supported CPU or power supply on hand to test with, you should seek an RMA, assuming your board is covered under warranty.
APa
I did, but it did not fix the issue.
I tested:
4 GB
HMT451S6BFR8A - PB N0 AA
8 GB
KVR16S11/8
and 1 GB
EBJ11UE6BASA-AE-E
I don't have another supported CPU, but I tested another power supply without success.
Thank you.
KL2
I tested:
4 GB
8 GB
KVR16S11/8
and 1 GB
EBJ11UE6BASA-AE-E
I'll state the obvious in that all of those RAM modules should work.
I'm guessing there are no extra devices plugged into the mainboard? (PCIe, Mini PCIe, USB, etc.)
It's too bad you don't have another CPU to try, it's always the last thing I suspect. A simple thing like dirty CPU contact pads can create some goofy errors.
There haven't been too many Intel boards that I couldn't make functional, but every once in awhile I would see one, and it sounds like you've got one.
If I think of something else, I'll post it up, but I'm pretty much out of ideas for this one.
Sorry I couldn't help more. Good luck
Community Manager
Hello:
Thank you very much to Gize2, for all the information provided and the troubleshoot steps recommended.
To Nick2015, at this point you basically tried all the troubleshoot steps that we recommend, and based on that it seems to be a problem with the board.
Since you do not have the option to use a different processor on this board, or to use your processor on a different board, the best thing to do wil be to replace the board.
As an option, if there is a PC repair store close to you, they might be able to swap parts for you, to make sure if the problem is the board or processor.
The board and processor have 3 years of warranty, so, if you purchased the board less than 3 years ago we can replace it for you.
If you are interested in the replacement, in order to do that, please get in contact directly with us through chat, email, online support or phone support, here is the link to do that, you just need to select the type of product you are interested in replacing and you will get those options:
http://www.intel.com/content/www/us/en/support/contact-support.html# @12 http://www.intel.com/content/www/us/en/support/contact-support.html# @12
Alberto
APa
You are right. There are no extra devices plugged into the mainboard.
I have to thank you again and I think that your information can help other people in order to fix issues.
@Alberto
Thank you. I will try to get a replacement.
Community Manager
Hello Nick2015:
Thank you very much for that information.
Once you get in contact with us directly we will provide all the details about the replacement process.
Alberto
