Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
No Windows 7 support for DG965WH, ever !!!???
Community Manager
Is it true that there will be no support for Windows 7 on the DG965WH motherboard? This seems to be what i'm reading, but frankly, I can't believe it.
What are the implications of this as I move to Windows 7, am I likely to encounter problems, or not?
~gs2gf
Community Manager
Hi GoSlow2GoFast
No is not compatible and there isn't any plans.
http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm
However Windows 7 pretty much install in every thing that you trough at it. Is solid and stable I had it installed on a number of systems "Very Old Systems" and so far I didn't have any problems.
I'm sure that it will be fine if you install it and if you have a problem with a particular device, install the Vista driver on it. That is what I have been doing and so far so good.
Span1shUk
Community Manager
I've been trying to install Windows7 (32 & 64 bit) on this board to no sucess. After hours of installation, in completes and the machine is very slow moving around with the mouse. Should I try installing the Vista drivers at this point? I also read that updating the BIOS might help also.
Community Manager
Please check with this post.
/message/75615# 75615 http://communities.intel.com/message/75615# 75615
May be you can get some more information from him.
Kind Regards,
Aryan.
Community Manager
Check the chart available at the following site:
It says DG965WH motherboard does not support Windows 7 OS.
Also refer the following link:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18246&ProdId=2375&lang=eng
But if you view the support site for the DG965WH motherboard, it shows a couple of windows 7 drivers
1) Chipset: Intel® Chipset Device Software for Intel® Desktop Boards
2) RAID: Intel® Rapid Storage Technology Driver for Intel Desktop Boards
May be Vista drivers will work on Windows 7 or Windows 7 built-in drivers may work for this motherboard but no driver support for Windows 7 from intel.
Community Manager
Win 7 - 64 works perfectly on my DG965WH board. Never installed any mainboard drivers, Win 7 does apparently have them all.
Community Manager
