Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
No Windows 7 support for DG965WH, ever !!!???
Is it true that there will be no support for Windows 7 on the DG965WH motherboard? This seems to be what i'm reading, but frankly, I can't believe it.
What are the implications of this as I move to Windows 7, am I likely to encounter problems, or not?
~gs2gf
Community Manager
Hi GoSlow2GoFast
No is not compatible and there isn't any plans.
http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm
However Windows 7 pretty much install in every thing that you trough at it. Is solid and stable I had it installed on a number of systems "Very Old Systems" and so far I didn't have any problems.
I'm sure that it will be fine if you install it and if you have a problem with a particular device, install the Vista driver on it. That is what I have been doing and so far so good.
Span1shUk
Community Manager
I've been trying to install Windows7 (32 & 64 bit) on this board to no sucess. After hours of installation, in completes and the machine is very slow moving around with the mouse. Should I try installing the Vista drivers at this point? I also read that updating the BIOS might help also.
Community Manager
Please check with this post.
/message/75615# 75615 http://communities.intel.com/message/75615# 75615
May be you can get some more information from him.
Kind Regards,
Aryan.
Community Manager
Check the chart available at the following site:
It says DG965WH motherboard does not support Windows 7 OS.
Also refer the following link:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18246&ProdId=2375&lang=eng
But if you view the support site for the DG965WH motherboard, it shows a couple of windows 7 drivers
1) Chipset: Intel® Chipset Device Software for Intel® Desktop Boards
2) RAID: Intel® Rapid Storage Technology Driver for Intel Desktop Boards
May be Vista drivers will work on Windows 7 or Windows 7 built-in drivers may work for this motherboard but no driver support for Windows 7 from intel.
Community Manager
Win 7 - 64 works perfectly on my DG965WH board. Never installed any mainboard drivers, Win 7 does apparently have them all.
Community Manager
