Intel® Desktop Boards
Peer-to-peer support only
11432 Discussions
No boot, no beep, only POST code LED display. Please help
GLORI1
Hello everybody and thank you for your help. And please excuse me for my approximate English.
Here is the problem. My PC (Intel DZ77RE-75K and Intel core i7-3770K) worked well for almost 3 years. 2 years with windows 7 installed on a mechanical HDD and almost 1 year with a SSD.
But it started freezing a few days ago. No BSOD, just freeze. But a weird freeze. My screen went black, all black. Hard reboot and then everything was OK for a few hours. Next day, I turn on the PC and after a few minutes, freeze. But this time, the screen was all white. Hard reboot and then everything was OK for a few hours. I thought it was a software problem because it happened when I was on the Internet. Maybe something with the new version of Firefox or flash player that I just installed.
But the next day, I turn on the PC and after a few minutes, freeze. The screen was all white. Hard reboot and... nothing. No boot. I turn on the PC, the fans are working but nothing but a black screen. I opened the case, clear CMOS, nothing. I unplugged SATA drives, optical drives, USB peripherals. Nothing. I tried with different RAM, with different video card, but each time I turn on the PC, the fans are working but nothing but a black screen. Then I removed everything, RAM and video card, and nothing. And I say nothing, not even beep errors. Just something on the POST code LED display. It was the same thing with RAM and video card installed. I made a little video.
https://drive.google.com/file/d/0B0UyI07D9bX5bGY4RVZnMU5jYjQ/view?pli=1 https://drive.google.com/file/d/0B0UyI07D9bX5bGY4RVZnMU5jYjQ/view?pli=1
If someone can help me, explain to me what is going on. If you need more information. If you need me to try something else. Please let me know.
Thank you
GLORI1
I answer my own question. I knew I had an old socket 1155 motherboard. So I replaced my Intel DZ77RE-75K with this one. I plugged everything on it: PSU, CPU, RAM, video card. And it worked. My PC boot.
So I think my Intel DZ77RE-75K is dead. Unfortunately, it has a 3 year warranty and my Intel DZ77RE-75K is 3 years and 3 months.
Ricardo_G_Intel1
If you want you can update the BIOS using the F7 key https://downloadcenter.intel.com/product/63247/Intel-Desktop-Board-DZ77RE-75K Downloads for Intel® Desktop Board DZ77RE-75K, http://www.intel.com/support/motherboards/desktop/sb/CS-030144.htm Desktop Boards — Instructions for F7 BIOS Flash Update or this can be like a video problem.
