Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
Older Intel D945PSN Board BIOS Identification
PMela1
Good day to all
I own the desktop board in caption (D945PSN), which has been "laid up" (deactivated) for some years now. It was bought as a full boxed version: Model BOXD945PSNLK, AA No. C96906-402, S/N BTSN53200901. I am trying to put it in service again, in order to build a PC, which will serve my country house needs, whenever this becomes necessary.
I intend to put an Intel Pentium D 960 (3.6 GHz) Processor on it, which also is available and idle for quite a while. By looking into Intel's List of Supported Processors for this board (http://www.intel.com/support/motherboards/desktop/d945psn/sb/CS-026897.htm]List http://www.intel.com/support/motherboards/desktop/d945psn/sb/CS-026897.htm), I can see that this processor is supported with BIOS version 0096 or greater.
However, I am not sure which BIOS version exists on my own board. I need therefore, to know how I can identify the existing BIOS version and if it becomes necessary, how I can update it with the newest one.
Thank you in advance.
Panagiotis (Peter) Melas
Greece
PMela1
Good day to all, again
I have just tried to operate this motherboard temporarily with another Intel processor (a Pentium 4, 660-3.6 GHz) and during displaying the BIOS main menu, I can read tha BIOS version is the following:
SN 94510J.86A.0044.2005.0711.1450
Apparently, this is an older BIOS version, therefore, it has to be updated with the newer one. The second part of my question it is still valid ((how I can update it).
