Intel® Desktop Boards
Peer-to-peer support only
Onboard DVI
84
DH67BL Where does the onboard DVI port show in Device Manager?
AlHill
Your graphics are shown in the device mangler under "display adapters".   There is no separate entry for DVI or HDMI.
[Windows 11 is the new Vista]
84
Thanks, Doc    My PCIe  video card (VGA) is showing, but no additional DVI port. The physical port is there, but it does not appear in the Device Manager
AlHill
You do not have a driver installed.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
84
Thanks, AlHill
AlHill
You are running Windows 10.   There is no Intel driver for your processor graphics for windows 10.   All you have is the Microsoft generic driver, which lacks features and performance.  It is probably only giving you the VGA port.
To avoid this, you can install an add-on graphics card and use that.
