Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
Onboard RAID controllers that support 8 disks?
CCopp
Do you sell any motherboards with a controller than can support advanced 8-disk raid arrays?
Silvia_L_Intel1
Hello Cecoppola,
We do not have motherboards that support 8 disks. The following link will provide you the products that have 9 SATA ports; however there are 6 Intel SATA ports, 2 Marvell SATA ports and 1 eSATA.
http://ark.intel.com/compare/63244,68567,63247 http://ark.intel.com/compare/63244,68567,63247
Something very important for you to know is that you cannot combine Intel SATA ports and Marvel SATA ports to create a Raid Array.
So that means, you can use 6 hard drives maximum to create RAID.
regards,
Silvia_L_Intel1
Hello Cecoppola,
regards,
CCopp
Are there any plans to release chipsets with native support for 8-disk arras?
What is your best PCI solution for an 8-disk RAID 10?
