Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
One of the raid 1 disk is failed how should i proceed
FFurk
I am using asus P8Z77-V motherboard and i have setup the raid in the begining from computer start up CTRL-I
Now i have ordered another identical driver and copied all files in the left raid drive to new drive
However i still not added the new drive to the raid build
Here the tricky part. I suspect the other drive can also have problem. Thus, i want to verify it
In order to do so, i have to delete the raid volume or not?
If i delete the raid volume from CTRL-I in the start up, how can i setup the raid 1 again without data loss again?
So how should proceed? Just add the new drive to the current raid configuration from Intel Matrix Storage manager or delete the volume from boot CTRL-I , check the disk and recompose raid 1?
thank you
Windows 8.1
Intel Raid Storage Manager 14.8.0.1042
By the way the broken disk was SeaGate ST3000DM001 - it wasn't even 2 years old
n_scott_pearson
Super User Retired Employee
If you delete the RAID volume, you lose the contents of the drives. Don't do that. Add the new drive to the array and go from there...
n_scott_pearson
Community Manager
Hi MonsterMMORPG,
Scott is right, it is necessary to rebuild the RAID array first with the replacement HDD then, if you want you can change the second HDD later.
Regards,Mike C
