Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
Only showing S/PDIF option on audio settings
Martins
We've recently received 3 intel H55 desktop computers and we can't connect any P2 speaker or microphone, cause windows is is only showing Digital Audio (S/PDIF) inside audio configuration.
I'm using windows 10 on all three machines, but i've already tried on windows 7, and the problem persists.
All drivers seems to be updated as well. Can someone help me solve this please?
thanks.
(the prints are in portuguese, but you can have an idea)audio 1.pngaudio 2.pngreprodutionreprodutionrecordrecord
AlHill
Ok, the boards use the H55 chipset, but who made the boards?  Provide the manufacturer and model number.
Martins
Thank you for the answer.
This is the information extracted from cpu-z
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
Martins
Spoiler
Computador (Computer)
INTEL H55
Fabricante do sistema (System Manufacturer) To Be Filled By O.E.M.
Modelo do sistema (System Model) To Be Filled By O.E.M.
Tipo de sistema (System Type) Desktop
Fabricantes da motherboard (Motherboard Manufacturer) INTEL
Motherboard (Motherboard Product) INTEL H55
Versão (Version) INTEL
Versão do BIOS (BIOS Version) BIOS MESSAGE:Intel H55/H57 Series Ver:3.0N (2018/10/12)
Data (Date) 12/10/2018
Versão do SMBIOS (SMBIOS Version) 2.6
Sistema operacional (Operating System)
Microsoft Windows 10 Home (64 bits)
Versão (Version) 2004
Compilação do sistema operacional (OS Build) 10.0.19041
Construir filial (Build Branch) vb_release
Locale Português (Brasil)
Diretório do Windows (Windows Directory) C:\Windows
Diretório do sistema (System Directory) C:\Windows\system32
Versões do .NET Framework (.NET Framework Versions) 4.0.0.0, 4.8.04084
Navegador da Internet padrão (Default Internet Browser) Internet Explorer 11.388.19041.0
Navegadores de Internet instalados (Installed Internet Browsers) Google Chrome, Internet Explorer 11.388.19041.0, Microsoft Edge
Processador (Processor)
Intel® Core™ i5 CPU 650 @ 3.20GHz
Detalhes do dispositivo (Device Details)
Fabricante (Manufacturer) GenuineIntel
Descrição (Description) Intel64 Family 6 Model 37 Stepping 2
Arquitetura (Architecture) x64
Número de núcleos (# of Cores) 2
Nº de threads (# of Threads) 4
Frequência baseada em processador (Processor Base Frequency) 3200 MHz
Cache nível 2 (Level 2 Cache) 512 Kb
Cache nível 3 (Level 3 Cache) 4096 Kb
ID do processador (Processor Id) 0x20652
Revisão (Revision) 9474
Disponibilidade (Availability) Funcionando com a potência máxima (Running at full power)
Gráficos (Graphics)
Intel® HD Graphics
Compatibilidade do adaptador (Adapter Compatibility) Intel Corporation
Processador de vídeo (Video Processor) Intel® HD Graphics (Core i5)
Resolução (Resolution) 1920 x 1080
Bits por pixel (Bits Per Pixel) 32
Número de cores (Number of Colors) 4294967296
Taxa de atualização - Atual (Refresh Rate - Current) 60 Hz
Taxa de atualização - Máxima (Refresh Rate - Maximum) 75 Hz
Taxa de atualização - Mínima (Refresh Rate - Minimum) 59 Hz
Provedor (Provider) Intel Corporation
Versão (Version) 8.15.10.2900
Data (Date) 26/11/2012
Tipo de DAC do adaptador (Adapter DAC Type) Internal
RAM do adaptador (Adapter RAM) 3,75 GB
Status Este dispositivo está funcionando corretamente. (This device is working properly.)
Localização (Location) PCI bus 0, device 2, function 0
ID do dispositivo (Device Id) PCI\VEN_8086&DEV_0042&SUBSYS_00428086&REV_12\3&11583659&0&10
Áudio (Audio)
High Definition Audio Device
Provedor (Provider) Microsoft
Nome (Name) HdAudio.sys
Versão (Version) 10.0.19041.264
Data (Date) 05/09/2020
ID do dispositivo (Device Id) HDAUDIO\FUNC_01&VEN_8086&DEV_2804&SUBSYS_80860101&REV_1000\4&D2866D3&0&0301
ID do dispositivo (Device Id) HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_10EC0000&REV_1003\4&D2866D3&0&0201
Rede e E/S (Networking and I/O)
Realtek PCIe FE Family Controller
Fabricante (Manufacturer) Realtek
Instalado (Installed) True
Endereço MAC (MAC Address) 00:E0:4C:D4:FC:99
Nome do serviço (Service Name) rt640x64
Versão (Version) 9.1.410.2015
Data (Date) 04/10/2015
ID do dispositivo (Device Id) PCI\VEN_10EC&DEV_8136&SUBSYS_012310EC&REV_07\01000000364CE00000
Revisão (Revision) 07
Memória (Memory)
8 GB
Memória física - Total (Physical Memory - Total) 8 GB
Memória física - Disponível (Physical Memory - Available) 5,02 GB
Memória virtual - Total (Virtual Memory - Total) 9,23 GB
Memória virtual - Disponível (Virtual Memory - Available) 6,48 GB
Arquivo de página (Page File) C:\pagefile.sys
Espaço de arquivo de página (Page File Space) 1,25 GB
Armazenamento (Storage)
PNY USB 2.0 FD USB Device
Capacidade (Capacity) 29,74 GB
Versão do firmware (Version) 1100
Número de série (Serial Number) AFA27H33YD35000544
Partições (Partitions) 1
Versão (Version) 10.0.19041.1
Data (Date) 21/06/2006
ID do dispositivo (Device Id) USBSTOR\DISK&VEN_PNY&PROD_USB_2.0_FD&REV_1100\AFA27H33YD35000544&0
Sistema de arquivo (File System) FAT32
Compactado (Compressed) False
Capacidade (Capacity) 29,73 GB
Espaço livre (Free Space) 20,09 GB
ST3500312CS ATA Device
Capacidade (Capacity) 465,26 GB
Versão do firmware (Version) CA12
Número de série (Serial Number) 6VV3TT1P
Partições (Partitions) 3
ID do dispositivo (Device Id) IDE\DISKST3500312CS_____________________________CA12____\5&10EFD1E3&0&0.0.0
C:
Sistema de arquivo (File System) NTFS
Capacidade (Capacity) 464,71 GB
Espaço livre (Free Space) 409,95 GB
Martins
are you able to see the specs inside spoiler tab?
n_scott_pearson
Super User Retired Employee
I believe that your problem is caused by the fact that you have only the generic driver from Microsoft. These boards typically use a RealTek audio CODEC. You might want to try installing the RealTek driver package (available on their site).
Hope this helps,
Martins
Thank you, friend. I will try that and return a feedback later.
