Intel® Desktop Boards
Peer-to-peer support only
11431 Discussions
PLACA INTEL DX79SR
Community Manager
Tengo una placa intel dx79sr con un procesador Ci7 3960x genuina
la placa me vino con el dvd de instalación ,el problema esta cuando quiero instalar solo me sale la ventana de instalación pero no me deja instalar, solo tengo que instalar manualmente
les agradecería su respuesta
gracias
n_scott_pearson
Super User Retired Employee
This is absolutely true; the Express Installer CDs are no longer supported. That said, they are so horribly out of date that you really shouldn't be using them anyway. You need to go to the downloads page for your board (here: https://downloadcenter.intel.com/product/65143/Intel-Desktop-Board-DX79SR Downloads for Intel® Desktop Board DX79SR), download all of the latest driver and software packages for your chosen O/S and then manually install them. For those packages that come as a ZIP archive, unzip the entire contents of this archive into a folder on the target machine and then execute the included Setup.exe program.
Hope this helps,
Community Manager
cuando por primera ves instale el windows 7 si salia para instalar el dvd de instalación pero decía que faltaba lenguaje como si fuera en ingles
de todos modos gracias por el dato mi estimado amigo
Community Manager
richard3000, try installing the drivers manually from the link provided and let me know it goes.
Amy.
Community Manager
/thread/106934 richard3000,
Were you able to install the drivers manually?
Amy.
