My new Filco keyboard will only work via USB, no PS/2.
I have the latest BIOS. I reset all setting to default and then reconfigured. Made sure the PS/2 port is enabled (checked).
I tried a different keyboard using the USB to PS/2 adapter that was supplied with the Filco, and the other keyboard doesnt work either.
Hello Zorlac, I am sorry for this issue.
Please consider that if your keyboard is USB, probably the converter is not working. I suggest testing with a native PS/2 keyboard or mouse instead.
Another possible troubleshooting step is testing the motherboard with minimum components out of the case, in a non-conductive surface.
Otherwise, there is a chance that the port on the motherboard is not working. If so, you may contact your local Intel® support team for a warranty replacement.
http://www.intel.com/p/en_US/support/contactsupport Contact Support
Thank you for our response! I tried a native PS/2 keyboard and it works. This points to a problem with the adapter as you said. I then tried several adapters I was able to find and NONE of them work.
I am assuming that no USB to PS/2 adapter is going to work for this specific Filco keyboard on my Z87 system board...
Does Intel recommend a specific make/model of adapter to use?
We usually encourage a direct connection between devices.
We have a list of tested peripherals, which includes keyboards, but no trace of such adapters at this moment.
http://www.intel.com/support/motherboards/desktop/db-dz87klt-75k/sb/CS-034266.htm Intel� Desktop Board DZ87KLT-75K; Tested peripherals
I am sorry for any inconvenience.
Just wanted to update this post.
I was finally able to test my Filco keyboard with the USB to PS/2 adapter on another computer. It works perfect. So this tells me something is going on with the DZ87KLT-75K PS/2 combo port and there is nothing wrong with the Filco keyboard USB to PS/2 adapter that was included with the keyboard.
Why would a native PS/2 Microsoft keyboard work in said port, but not a Filco using a USB to PS/2 adapter? The Filco works great using USB on the same system board and works great via PS/2 on a different system board.
I am sorry; this seems to be a compatibility issue.
Received my RMA board. I have done a full clean reformat with Windows 8.1 Pro x64, latest patches and latest drivers.
- Board is a rev 305 instead of rev 304
- Board appears to be new
- Board allowed me to upgrade BIOS to 0447
- PS/2 port still doesnt like my Filco keyboard. It worked once at POST to get me into the UEFI interface and then once in there it quit and hasnt worked since. I have to use USB still.
