Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
PSU won't turn on (D925XECV2)
MMISS18
Hi all,
I have an old PC with a D925XECV2 motherboard. But I have an issue regarding turning on the PSU.
When I press the "turn on" switch nothing happens. I have tried shorting the pins on the motherboard, but with no success, so I don't think the switch itself is defective. I have also tried to short the PSU_ON pin (Green wire, pin 14) on the PSU to ground and then it runs perfectly. If I keep PSU_ON shorted the PC is able to boot and run perfectly.
I suspect that the issue is related to the power on/off circuitry on the motherboard. But does anyone know what to look for and which component to change?
Thanks in advance,
cgr
Silvia_L_Intel1
CGR, if the issue is related to a component in the motherboard itself, you would need to replace the whole unit. However, since this motherboard is a very mature product, I think it is not longer under warranty. I'm sorry.
You may want to try the system out of the chassis just to make sure there isn't a grounding problem.
