Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
PXE-E61 & PXE-M0F Errors While Booting
APras8
I am receiving the following errors while booting my desktop:
PXE-E61 - Media test failure, check cable
PXE-M0F - Exiting Intel Boot Agent
As mentioned below, I have disabled network boot feature. I have also tried replacing the SATA cable and port. Finally, I tried to update the BIOS version to 0103. But for some reason the update is NOT happening. I press F7 to update BIOS, follow all the subsequent steps and press ENTER in the last step to update BIOS. At this moment, my computer (or BIOS) stops responding. By god, the current version does not get corrupted, but the point is that BIOS update is just not happening for reasons unknown to me.
Please help!
System Information:
BIOS Version : EBH7710H.86A.0053.2012.0213.1543
Processor Type : Intel Core i5-3550 CPU
Product Name : DH77EB
Version : AAG39073-304
Serial Number : BQEB229002LB
Intel Management Engine Firmware : 8.0.1.1399
SATA Port 1 : WDC WD5000AZRX (500.1GB-6.0Gb/s)
Boot Drive Order: [P1: WDC WD5000AZRX-00A8L]
The following options are disabled:
Boot to Optical Devices
Boot to Removable Devices
Boot to Network
UEFI Boot
Fast Boot > General Optinmization is enabled
Akash
Silvia_L_Intel1
Hello Akash Prashant, thanks for joining the Intel Community.
I was checking the BIOS versions available for this motherboard on the download center, and there are 13 different files.
I would like to tell you that going straight to the latest version shouldn't be a problem, technically speaking. However based on experience, there is always chance.
I would recommend checking the BIOS Update Release Notes on this URL. You will be able to see the fixes and features included on each version.
http://downloadmirror.intel.com/24426/eng/EB_0103_ReleaseNotes.pdf http://downloadmirror.intel.com/24426/eng/EB_0103_ReleaseNotes.pdf
These are some important versions you could flash on your system.
