Intel® Desktop Boards
Peer-to-peer support only
11435 Discussions
Pc can be turned off
zevs
Hello, my PC can be turned off at any time, it can be turned off 5 times when turned on. I did a stress test aida64 and autoburner can work normally for 20 minutes. Even when turned on, there was a ram overclocking error. what could be the problem? what components? ram? Thank.
AlHill
What PC?
Provide the processor model number.
Provide the motherboard model and manufacturer.
Provide the operating system AND VERSION.
Doc
zevs
Gigabite GA-Z68P-DS3 ~2012 (time does not go astray)
ASUS 1050ti
I5 2500 Win 10(1803)/7 x64
Corsair cmx 4+4gb
AlHill
Your Sandy Bridge processor is not supported on Windows 10:
https://ark.intel.com/content/www/us/en/ark/products/52209/intel-core-i5-2500-processor-6m-cache-up-...
https://www.intel.com/content/www/us/en/support/articles/000006105/processors.html
As far as the PC turning itself off, I would check your cooling/thermal components, clean any dust blockages, and perhaps even re-do the thermal past.
I would also try a different power supply..
Also, your processor is no longer supported.
Doc
zevs
thermal grease is in good condition and on the south (north) bridge too. Until I removed 2 ssd disks, it worked fine on windows 10 4k tv 3840x2160 2 years
AlHill
So, the problem began after you remove two SSD. Sounds like you introduced some problem. On equipment this old, that is easy to do.
Still, your processor is not supported.
Doc
zevs
Yes, I know, now I have a good PC, I need it to work for my brother, I'll take it to the service. thanks for the help
