Olá, tenho um PC com a placa mãe DH55TC, esta possui dois pentes de memória RAM de 2 GB,DDR3, de 1333 MHz Maxvision. Comprei um pente de RAM DDR3 4GB 1333MHz da Kingston, instalei no pc, este não liga, testei o pc apenas com esta memoria nova, o pc continua sem funcionar. Será que é problema na memória?
Hello boniocezar,
Thank you for joining the Intel communities.
If you install the RAMs that you had before, does you system work fine?
If yes, this could be a compatibility problem, try installing one at a time, if that does not work try updating the BIOS you can download the latest BIOS version for your system at the following link:
https://downloadcenter.intel.com/download/20725/BIOS-Update-TCIBX10H-86A- Download BIOS Update [TCIBX10H.86A]
BIOS Flash Update Instructions:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005724.html F7 BIOS Flash Update Instructions for Boards and Kitshttp://www.intel.com/content/www/us/en/support/boards-and-kits/000005724.html
If the suggestions above do not solve your problem please reply with your RAM part number to check compatibility.
Ivan
