Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Possible DQ77MK ACPI bug
I'm using a DQ77MK desktop board with BIOS MKQ7710H.86A.0050.2012.0830.1022 08/30/2012 alongside an i7-3770 CPU.
While loading Xen I came across the following:
# xm dmesg | grep ACPI
(XEN) 000000008e2d6000 - 000000008e2e6000 (ACPI data)
(XEN) 000000008e2e6000 - 000000008e40b000 (ACPI NVS)
(XEN) 000000008e6b0000 - 000000008e6f3000 (ACPI NVS)
(XEN) ACPI: RSDP 000F0490, 0024 (r2 INTEL)
(XEN) ACPI: XSDT 8E2DA080, 007C (r1 INTEL DQ77MK 32 AMI 10013)
(XEN) ACPI: FACP 8E2E41F0, 010C (r5 INTEL DQ77MK 32 AMI 10013)
(XEN) ACPI Warning (tbfadt-0232): FADT (revision 5) is longer than ACPI 2.0 version, truncating length 0x10C to 0xF4 [20070126]
(XEN) ACPI: DSDT 8E2DA188, A061 (r2 INTEL DQ77MK 32 INTL 20051117)
(XEN) ACPI: FACS 8E409080, 0040
(XEN) ACPI: APIC 8E2E4300, 0092 (r3 INTEL DQ77MK 32 AMI 10013)
(XEN) ACPI: FPDT 8E2E4398, 0044 (r1 INTEL DQ77MK 32 AMI 10013)
(XEN) ACPI: TCPA 8E2E43E0, 0032 (r2 INTEL DQ77MK 32 MSFT 1000013)
(XEN) ACPI: MCFG 8E2E4418, 003C (r1 INTEL DQ77MK 32 MSFT 97)
(XEN) ACPI: HPET 8E2E4458, 0038 (r1 INTEL DQ77MK 32 AMI. 5)
(XEN) ACPI: SSDT 8E2E4490, 036D (r1 INTEL DQ77MK 32 INTL 20091112)
(XEN) ACPI: SSDT 8E2E4800, 09AA (r1 INTEL DQ77MK 32 INTL 20051117)
(XEN) ACPI: SSDT 8E2E51B0, 0A92 (r1 INTEL DQ77MK 32 INTL 20051117)
(XEN) ACPI: DMAR 8E2E5C48, 00B8 (r1 INTEL DQ77MK 32 INTL 1)
(XEN) ACPI: ASF! 8E2E5D00, 00A5 (r32 INTEL DQ77MK 32 TFSM F4240)
(XEN) ACPI: 32/64X FACS address mismatch in FADT - 8e409080/0000000000000000, using 32
I've highlighted has seems to me a bug on the BIOS implementation of ACPI. Looking around intel.com website I couldn't find a reasonable technical support e-mail or bug reporting tool.
Can someone provide a valid Intel contact to expose the bug and hopefully correct it the next BIOS version?
Thanks!
AP16
Valued Contributor III
Board have ACPI v3 support, and Xen support for v3 tables is preliminary. Check BIOS Setup for ACPI version declaration setting, try with 2.0 level.
Community Manager
Thanks for the reply JFFulcrum.
I don't see any ACPI v2.0 or v3.0 selection option under BIOS > Power. Maybe it's named differently.
Any pointers?
