Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Power Supply for DZ87KLT-75K
KHall7
Hello
I just finished a new build using a DZ87KLT-75K board. Everything seems to be working fine, but I have noticed some issues when waking up the computer - sometimes it doesn't want to wake, and I have to hit the reset button.
Since I re-used my Antec P180 case and PSU, I suspect the power supply, which is an Antec TruePower Trio 650W. My board came with a yellow sheet that said I could find compatible PSUs at www.intel.com/go/powersupplies. I attempted to go to this url, had to register and sign in, but got a big "Permission Denied" instead of a list of PSUs.
Anyone want to point me to a list that is accessible?
Jose_H_Intel1
Hello trendfirst,
Below you can find the list of tested components. You may try resetting / updating the BIOS though.
http://www.intel.com/support/motherboards/desktop/db-dz87klt-75k/sb/CS-034266.htm Intel� Desktop Board DZ87KLT-75K; Tested peripherals
JRose17
I saw the list. Thanks for the link. The Antec HPC 850 platinum is not on there but the 1200 is. How safe is it to assume this one will be compatible? It has the 0 watt minimum load I've seen mentioned as a requirement.
Jose_H_Intel1
Perhaps the power supply manufacturer may have more information regarding the similarities or differences between those two models.
