Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
Pressing F2 does not take me to BIOS set-up
TGoug1
Hello! DZ77RE-75K BIOS GA0063
Pressing F2 does not take me to BIOS set-up. Here is what I have tried....
2 different keyboards (in case a keyboard problem)
3 different USB ports on the motherboard.
Holding down the F2 key continuously
Quickly pressing F2 key
I assembled this computer in January 2013 and have repeatedly accessed the BIOS set-up screen.
I have been able to change the BIOS jumper to go into BIOS maintenance mode, but the F2 key
should work and would obviously be much easier!!!
Thanks for any help you can give!
Silvia_L_Intel1
Hello Tom,
What we can recommend to you is to go ahead and update the BIOS to version 0064. You may want to use the F7 method, please ignore step # 5. http://www.intel.com/support/motherboards/desktop/sb/CS-030144.htm http://www.intel.com/support/motherboards/desktop/sb/CS-030144.htm
You can also try the installation removing the BIOS jumper and using the BIOS recovery method, instructions are here: http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS update
I also recommend you to clear the CMOS, removing the battery for 30 minutes.
Please proceed to test the motherboard with minimal configuration, such as Motherboard, processor, power supply and 1 memory stick.
Regards.
TGoug1
Hello!
Thanks! I will give this a try as soon as I can.
Silvia_L_Intel1
Tom, in addition to that, another good step is to test accessing the BIOS by using the Back To BIOS button on the motherboard.
TGoug1
Hello Sylvia!
I first tried to update to BIOS version 64 using the Express method. While the messages indicated the update was successful, when I checked the BIOS screens, I am still
on version 63. The F2 key still did not work, so I used the Back to BIOS button.
Next I tried to update the BIOS using the F7 method with the file on a USB. I was able to press F7, locate the file and start the process. However, the computer booted twice
without any other messages. when I checked the BIOS screens, I am still on version 63. The F2 key still did not work, so I used the Back to BIOS button.
I did notice, while working in the BIOS screens, my keyboard did not seem to work. My mouse functioned, however. At one point I needed to press "Y" and could not, so I had
to power down the computer and go back into the BIOS to a place where I could use my mouse.
What do you suggest next?
Thanks for your help!
Regards, Tom
RMors2
If you are using a USB keyboard, try attaching it to one of the USB 3.0 ports closest to the HDMI port on the back panel. Also, enter BIOS setup using the "back to BIOS" button method and make sure all of the options under the boot tab for optimizations are disabled (not checked).
RMors2
continuing from my last...
and make sure that the USB .30 hub presence option is selected (checked) in the USB tab of the Devices and Peripherals section of the BIOS setup.
TGoug1
Hello! Changing the keyboard to the USB 3 WORKED!
I am able to access the BIOS by using F2!
Thanks!!!
Silvia_L_Intel1
Tom,
I'm glad to know that your system is working now.
