Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
Problem in DG41TY motherboard with Windows 7
Community Manager
Hi All,
I have core 2 duo 2.2 ghz and recently changed my motherboard from asus to intel DG41TY.
I tried to install windows 7 several times, however every time the OS installation process continuing till giving the credentials to finish the installation after that i should have get the desktop screen but I'm getting the welcome screen after the machine automatically started to restart after the restart a blinking black screen and nothing more than that.
Please note the following,
1) Windows xp is loading correctly
2) I tried different media of Windows 7, but the outcome was same. The same was and is working fine in my brothers desktop.
3) I even tried different flavour of windows 7 but the outcome was same. The same was and is working fine in my brothers desktop.
4) I have previously installed windows 7 a ton of times and know that I am following the correct procedure
I assume either windows 7 cannot be loaded at all on intel DG41TY with core 2 duo 2.2 ghz or their is some trick to get pass this issue.
Your quick help is appreciated.
Silvia_L_Intel1
Hello MD SHAMS NEZAMI,
First of all, I would like to inform you that this motherboard has been out of support since June 29, 2012. http://www.intel.com/support/motherboards/desktop/sb/CS-033578.htm http://www.intel.com/support/motherboards/desktop/sb/CS-033578.htm
However, here are our recommendations for this issue:
I recommend you to update the BIOS of your motherboard. Please check which BIOS version is installed. Check how many versions are between the current BIOS and the latest one. Then, depending on that, try to install 1 or 2 version before going to the version 0045.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DG41ty https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DG41ty
You may also try removing the CMOS battery. Leave the system without it for about an hour. Then put it back on and restart the system. http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
Silvia_L_Intel1
