So my motherboard is DG31PR, and I want to update bios via Boot CD.
I made the boot cd, with iflash2.exe and PR0071.bio inside(just this files and the boot ones).
And when I boot the cd and Im in de famous A: of DOS, I write 2IFLASH /PF Pr0071.bio, and it says invalid command or filename.
I tried to write IFLASH2 too.... and a lot of commands, nothing works.
Help me please.
No one knows the answer?? TT
Hello XTfRaN,
Please check the following links; they will provide you the instructions on how to update the BIOS on your motherboard. http://downloadmirror.intel.com/18881/eng/BIOS%20Update%20Readme.pdf http://downloadmirror.intel.com/18881/eng/BIOS%20Update%20Readme.pdf
http://www.intel.com/support/motherboards/desktop/sb/CS-022312.htm http://www.intel.com/support/motherboards/desktop/sb/CS-022312.htm
Please remember that if the system is not giving you problems, a BIOS update is not necessary.
Which BIOS version are you trying to flash/install on you system?
Regards.
