Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
Problem with DH61ZE motherboard and ATI Radeon HD5450 Graphic card
ASubr2
I recently bought an ATI Radeon HD5450 graphics card. I have two systems, one is Intel DG41RQ motherboard and the other one is DH61ZE.
Graphic card is working fine with the motherboard DG41RQ.
In the other hand DH61ZE mother board causing a blue screen error when I tried to boot through HD5450. I have tried different OS like WinXP, Win7, Win8. Tried installing catalyst (graphic card drivers) etc, but no use. Before going to the Desktop, the computer restarts.
Is this Graphic Card Compatible with the Motherboard or Is there any problem with the mother boards?
Silvia_L_Intel1
Hello Agurchand,
Please let me know which processor you are using on this system?
There is a new BIOS version 0116 that you may want to try. You can download the file on the following link: https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DH61be... https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DH61be...
Regards.
ASubr2
Hi Sylvia,
CPU: Intel® Pentium® Processor G630
I have already updated the BIOS to the latest version 0117. But no use, same problem is there still.
BIOS Version/DateIntel Corp. BEH6110H.86A.0117.2013.0704.1354, 7/4/2013
Agurchand
Silvia_L_Intel1
Agurchand,
Please test the board out of the chassis using minimum configuration such as Motherboard, processor, 1 memory stick and power supply. No video card.
Make sure you have the latest graphics drivers installed https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Deskt... https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Deskt...
Please test another PCI-e device on the board in order to discard it is defective.
The following link will show you the list of tested peripherals with a 6 series motherboard. There are some ATI video cards; however the one you are using is not there. I recommend you to contact ATI and ask them if they tested this video card on a 6 series board. http://www.intel.com/support/motherboards/desktop/dq67ep/sb/CS-032323.htm http://www.intel.com/support/motherboards/desktop/dq67ep/sb/CS-032323.htm
Since the video card is working on the DG41RQ motherboard, you may want to try updating the firmware of the device. Then, test the video card again on the DH61ZE motherboard.
If you continue having the same behavior after all this procedure, it has to be a compatibility problem between the board and the video card.
Regards.
