Intel® Desktop Boards
Peer-to-peer support only
11434 Discussions
Problem with Intel Driver and Support Assistant
Jorge4
The Intel Driver and Support assistant does not work for Windows 7. I have installed the Microsoft.NET Framework 4.8. When trying to run Intel Driver Support Assistant the following message appears: Microsoft.Net Framework required for Intel Driver & Support Assistant setup. I need to install the PCI Device Driver that seems not working. My PC runs under Windows 7 SP1. Thank you for your help, Jorge
