Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11461 Discussions
Problem with motherboard and memory module.
SPetr6
Hello, Could you please help me with this problem ?
I have got this motherboard - Intel Corporation, D915GUX (product), aac63985-401 (version), EV91510a.86a.0482 (bios version).
And I have got problem with this memory modules KVR400D2S4R3/2G. When I put in this module I receive 3x beeps and I am done. I also tried all positions on motherboard without changes. I also looked if this module is compatible with motherboard and it should be.
Could you please tell me where can be problem ? Thank you very much.
Silvia_L_Intel1
Hello Sedlis, first of all, I would need to let you know that this motherboard has been out of support since December 2008. http://www.intel.com/support/motherboards/desktop/sb/CS-028521.htm http://www.intel.com/support/motherboards/desktop/sb/CS-028521.htm
However, since the motherboard is running the latest BIOS available for it, my recommendations for this kind of memory problem are the following:
  • Test the system out of the chassis, minimal configuration please. (Motherboard, processor, power supply and video card) No memory.
  • Remove the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system.
http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
  • - Include 1 memory stick on DIMM # 1 and restart the system.
When did this behavior started? Any recent change you made on the system?
ZAgha
New Contributor II
@Sedlis
You are using server RAMs that are ECC registered & your MB isn't compatible with such RAMs. Hence, the 3 beeps "i.e. memory error".
So as Sylvia said:
"When did this behavior started? Any recent change you made on the system?"
