Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Problem with usb ports and sound
JGosa
I have a D945GCNL motherboard placed in my CPU with core2duo processor since 2008. Recently, my Iball smps stopped working so I got it replaced. After connecting smps, the windows showed a hardware failure on booting and after that I realised that my 4 usb ports have stopped working. Moreover, the system sound level has become very low and gives some noise at the output. However the keyboard which is connected above the ports is working fine. The sound problem was there before my old smps broke down. However the problem with the usb ports have come up after the new smps. Also, everything else works perfectly fine as it used to be earlier. I cant figure out the problem. I'm currently having a Windows 7 64bit OS on my desktop.
Kindly help!
TGold1
New Contributor II
Try running the USBScrub Utility from the link below.
http://www.getusb.info/review-usb-scrub-cleans-your-registry-of-old-usb-sticks/ USB Powered Gadgets and more..
The download link is at the end of the article.
Also run SFC /Scannow
The following link tells you how:
http://pcsupport.about.com/od/toolsofthetrade/ht/sfc-scannow.htm How To Use SFC Scannow to Repair Windows System Files
Then run chkdsk on your drives.
Good luck
Silvia_L_Intel1
Jaygosar, let me inform you that this motherboard has been out of support since June, 2010. http://www.intel.com/support/motherboards/desktop/sb/CS-031583.htm http://www.intel.com/support/motherboards/desktop/sb/CS-031583.htm .Also, Windows 7 is not a supported operating system for it therefore; there are no plans for making drivers hhttp://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm ttp://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm
These are the drivers available for this motherboard https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine... https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine...
What we can recommend you is to test the system out of the chassis, minimal configuration. (Motherboard with embedded processor, power supply and 1 memory stick).
Remove the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system.
http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
