Fiz a atualização da minha bh61br e correu tudo bem, porém o SO não inicia e o PC trava na tela da placa
Os procedimentos feitos foram:
0018 a 0043
0043 a 0048
0048 a 0099
A partir dai não consegui mais atualizar ate as 0120 pois na tela aparece o seguinte erro Fw update simple application error.
Alguém pode me ajudar ?
Ronaldo,
Can you get into BIOS Setup? If you can, do so and then scroll down to and open the Additional System Information scene. At the bottom of this display (you may have to scroll down to see it) will be a display of the Intel Management Engine (ME) firmware revision. Is this value either blank or set to 0.0.0.0? If so, it is an indication that the ME is not operating and this is usually the result of a failure during the update process. The way out of this state is via BIOS recovery.
You said you are currently running on BIOS 99, right? I suggest that you reinstall BIOS 99, but this time do it via the Recovery method. For more information, consult the following:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html?wapkw=bios+recovery Intel Desktop Boards Recovery BIOS Update Instructions
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005859.html Updating the BIOS to Support 3rd Generation Intel Core Processors
Once you have reinstalled BIOS 99 using the Recovery Method, you should be able to then install the subsequent BIOS releases. If this proves to be problematic, you can also try installing the subsequent BIOS releases using the Recovery Method.
Hope this helps,
Hello:
Thank you very much to N.Scott.Pearson for the information posted previously.
To chatubajj:
The BIOS recovery is always useful under this specific scenario. Please try that and let us know the results.
Could you please confirm the model of the board?
I looked for the BIOS 0099 in our web site, and it says that BIOS version is compatible with the following boards:
Intel® Desktop Board DH61BE
Intel® Desktop Board DH61ZE
Intel® Desktop Board DH61DL
Intel® Desktop Board DH61SA
Intel® Desktop Board DH61WW
Intel® Desktop Board DH61CR
The model of the board that you gave us is not showing there, so before you do the BIOS recovery please make sure you are using the correct BIOS version to avoid any problems with the update.
Here is the link where you can confirm the information above:
https://downloadcenter.intel.com/download/22413/BIOS-Update-BEH6110H-86A-?product=51856 https://downloadcenter.intel.com/download/22413/BIOS-Update-BEH6110H-86A-?product=51856
Any further questions, please let me know.
Alberto
Hello chatubajj:
I just wanted to check if you were able to confirm the model of your motherboard and if you need further assistance on this matter?
Alberto
