Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Problems with ICH10R and Samsung Spinpoint F3 HD103SJ
Hello all,
Monday i recieved two Samsung Spinpoint F3 HD103SJ and configured them in Raid 0 on my Intel ICH10R raid controller.
At random moments i get a error (which various what application is running from that disk at the time) while writing or reading from the disk.
Translated it saids error i cannot write/read from that disk, when i look at the raid manager program it shows me: raid failed 1 drive is missing.
It shows as if i disconnected one drive physically from my computer.
I did some research and noticed that some people with the exact same setup dont have any problems at all while others, like me have.
Maybe there is someone here or from Intel that can help me fix this.
Below here i give the information about my hardware setup.
Mainboard: Asus Rampage 2 Extreme
Socket: LGA 1366
Chipset: Intel X58
Raidchip: Intel ICH10R
Harddrive: 2x Samsung Spinpoint F3 HD103SJ
Memory: Triple Channel DD3 1600 Coirsar dominator.
VGA: Asus ATI 5870
Powersuply: Be quiet dark power 750W
If you need anymore information let me know.
Hoping someone can help me with this.
Highlighted
Community Manager
Highlighted
Community Manager
Hello PeterUK,
Thanks for the quick reply.
Any overclocking being done?
No i did not overclock.
Are you booting (and still can) from this RAID 0 for your OS?
Yes i can still boot i have three hd's 1 for my os and 2 samsung as raid 0
Have you installed RST?
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2101&DwnldID=18859&ProductFamily=Chips... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2101&DwnldID=18859&ProductFamily=Chips...
Yes u did install the latest version (the one above). Iam wondering if there is anything i can do mayb raidcontroller related that can fix this problem?
Highlighted
Community Manager
I have a Intel 915 GUX motherboard in my PC, it is broken and I need to replace it. I would like to know how do I know with what board to replace it. I know enough to be dangerous. I don't want to pay a small fortune for it either.
Marius
Highlighted
Community Manager
Its more likely your new drives are faulty or at least one is.
Do you use sleep or hibernation? Have you set "turn off hard disk after" to never in Power options?
Highlighted
Community Manager
I did not set that to never.
Going to try that.
The errors accure during usage.
What do you mean atleast one driver is faulty?
I can only have 1 raid driver isntalled correct ?
Highlighted
Community Manager
drive not driver
