Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11461 Discussions
Problems with intel motherboard DP67BG - Problemas con la placa intel dp67bg
Community Manager
hello everyone, well my problem is that when I'm listening to music appears to be dialog-connector is unplugged to plugged a connector, and read that updating the audio driver but already and done and nothing, and given what I mind is that only happens when the sounds are bass, and also other problem is that all brand temperatures well except the PCH that is always at 43 ° C in the same brand bios since the purchase has been so, and the last problem is that sometimes reaches the temperature dial PCH exceeded more than x temperature or memory or VR (voltage regulator) and the cpu fan starts spinning at maximum .. I do not understand why it happens, it rarely happens not very often that to happen but it's annoying as I have to restart everything is normal for otravez, temperatures across the system are stable. that's why I have doubts about it, someone who has a mother like having similar problems? Thanks for your answers! and an apology if I have spelling errors use the google translator
hola todos, bueno mi problemas es que cuando estoy escuchando musica me aparece el dialogo de se a desenchufado un conector- se a enchufado un conector, e leido que actualizando el controlador de audio pero ya lo e hecho y nada, lo que me e dado cuenta es que solo sucede cuando los sonidos son graves, y otro problema tambien es que en las temperaturas todo marca bien excepto la del PCH que siempre esta en 43° C en la bios marca igual desde que la compre a sido asi, y el ultimo problema es que a veces llega a marcar que la temperatura del PCH se excedio mas de x temperatura o la de la memoria o el VR (voltage regulator) y el ventilador del cpu empieza a girar al maximo.. no entiendo por que sucede, es raro que pase no es muy frecuente que pase eso pero es molesto ya que tengo que reiniciarla para que todo este normal otravez, las temperaturas de todo el sistema son estables. es por eso que tengo duda sobre eso, alguien que tenga una mother igual que tenga problemas similares? gracias por sus respuestas!
Community Manager
You have reached the Intel AppUp(R) center support group and currently we can only provide technical assistance for issues related to the Intel AppUp(R) center client. You can find more information about the Intel AppUp(R) center here:
http://www.appup.com/what-is-appup/index http://www.appup.com/what-is-appup/index
I'm going to reroute your question to our Desktop Boards technical support department, they will be more than glad to assist you with your question.
Sergio S.
Intel AppUp(R) center Support
