Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
RST BSOD Intel rapid storage Bugcheck code: 0xD1 Sony Vaio SVE1712BCXB Bios R0170D6
sssss1
I get many crashes like these : http://www.google.com/search?q=iastora.sys iastora.sys seems to be the culprit. (Win8.1 Sony Vaio SVE1712BCXB Bios R0170D6)
On Sat 11/21/2015 4:50:33 AM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\112015-6562-01.dmp
This was probably caused by the following module: http://www.google.com/search?q=iastora.sys iastora.sys (0xFFFFF801C1296034)
Bugcheck code: 0xD1 (0xFFFFD00020DAA3EB, 0x2, 0x0, 0xFFFFF801C1296034)
Error: http://www.google.com/search?q=MSDN+bugcheck+DRIVER_IRQL_NOT_LESS_OR_EQUAL DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\drivers\iastora.sys
product: http://www.google.com/search?q=Intel%20Rapid%20Storage%20Technology%20driver%20 Intel Rapid Storage Technology driver
company: http://www.google.com/search?q=Intel%20Corporation Intel Corporation
description: Intel Rapid Storage Technology driver - x64
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: iastora.sys (Intel Rapid Storage Technology driver - x64, Intel Corporation).
I tried to update from 12.8.0.1016 to 14.5.0.1081 or 14.6.0.1029 and others in-between.
I always get in my IntelRST.log:
E Win32 exception occurred!!
2015:11:22 13:47:30:068: Error code: 0x4E24 (20004)
2015:11:22 13:47:30:068: Error text: ''
2015:11:22 13:47:30:068: Extended error text: 'Error in device matching'
2015:11:22 13:47:30:068: Debug info: 'Setup.cpp (257)'
How do I read those Intel RSTlog files?
What does Error code 0x4E24 (20004)
My origina question how do I get rid of http://www.google.com/search?q=iastora.sys iastora.sys BSOD?
How do I find out what is the newest IntelRST?
Wouldn't it be nice if instead of trowing a meaningless error it could tell: "The latest version you can install on your system is X.X.X.X and her is the link to get it....."
I have spent considerable time trying to prevent http://www.google.com/search?q=iastora.sys iastora.sys errors but I am getting nowhere.
sssss1
Hardware info
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.436 MHz
Sys timer 1.000 KHz
Processor 1
Name Intel Core i5 3210M
Codename Ivy Bridge
Specification Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
Package (platform ID) Socket 988B rPGA (0x4)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1
Technology 22 nm
TDP Limit 35 Watts
Core Speed 2893.7 MHz
Multiplier x FSB 29.0 x 99.8 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 3 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 25x
Max turbo ratio 31x
Max efficiency ratio 12x
Min Power 24 Watts
O/C bins none
Ratio 1 core 31x
Ratio 2 cores 29x
Ratio 3 cores 29x
Ratio 4 cores 29x
TSC 2494.6 MHz
APERF 2893.8 MHz
MPERF 2494.4 MHz
Chipset
Northbridge Intel Ivy Bridge rev. 09
Southbridge Intel ID1E59 rev. 04
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 16384 MBytes
Channels Dual
Memory Frequency 798.3 MHz (1:6)
CAS# latency (CL) 11.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 11
Cycle Time (tRAS) 28
Command Rate (CR) 1T
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
MCHBAR registers
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format SO-DIMM
Manufacturer (ID) (7F7F7F7F7F7F7F9B)
Size 8192 MBytes
Max bandwidth PC3-12800K (800 MHz)
Part number
Serial number FFFFFFFF
Manufacturing date Week 39/Year 15
Number of banks 8
Nominal Voltage 1.28 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC # 1 5.0-5-5-13-18 @ 363 MHz
JEDEC # 2 6.0-6-6-16-22 @ 436 MHz
JEDEC # 3 7.0-7-7-18-25 @ 509 MHz
JEDEC # 4 8.0-8-8-21-29 @ 581 MHz
JEDEC # 5 9.0-9-9-23-32 @ 654 MHz
JEDEC # 6 10.0-10-10-26-36 @ 727 MHz
JEDEC # 7 11.0-11-11-28-39 @ 800 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Size 8192 MBytes
Part number
Number of banks 8
EPP no
XMP no
AMP no
Mainboard Model VAIO (0x0000012F - 0x00003158)
LPCIO
LPCIO Vendor NS
LPCIO Vendor ID 0xFF02
LPCIO Chip ID 0xFC
LPCIO Revision ID 0x58
Config Mode I/O address 0x4E
Config Mode LDN 0x9
Hardware monitor Battery
Voltage 0 12.33 Volts [0x3026] (Current Voltage)
Capacity 0 62640 mWh [0xF4B0] (Designed Capacity)
Capacity 1 50670 mWh [0xC5EE] (Full Charge Capacity)
Capacity 2 49660 mWh [0xC1FC] (Current Capacity)
Level 0 20 pc [0x50] (Wear Level)
Level 1 98 pc [0x62] (Charge Level)
DMI BIOS
vendor Insyde Corp.
version R0170D6
date 03/13/2012
ROM size 6656 KB
DMI System Information
manufacturer Sony Corporation
product SVE1712BCXB
version C904P8D9
DMI Processor
manufacturer Intel(R) Corporation
model Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
clock speed 2500.0 MHz
FSB speed 100.0 MHz
multiplier 25.0x
DMI Memory Device
designation SODIMM1
format SODIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Memory Device
designation SODIMM2
format SODIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
Display adapter 0
Name AMD Radeon HD 7650M
Memory size 1024 MB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x104D)
Model ID 0x6841 (0x90AC)
Performance Level 0
windows Version Microsoft Windows 8 (6.2) 64-bit (Build 9200)
DirectX Version 11.0
IUman
Hello rosetta99,
Thank you for joining the Intel communities.
You can try downloading the Intel® Rapid Storage Technology at the following link:
https://downloadcenter.intel.com/download/25165/Intel-Rapid-Storage-Technology-Intel-RST-RAID-Driver https://downloadcenter.intel.com/download/25165/Intel-Rapid-Storage-Technology-Intel-RST-RAID-Driver
Also, it will be good to update your chipset driver before installing the latest IRST software, based on the system model you have you can download that driver and all of the drivers from your system manufacturer website at:
https://esupport.sony.com/US/p/model-home.pl?mdl=SVE1712BCXB&template_id=1&region_id=1&tab=download# /downloadTab https://esupport.sony.com/US/p/model-home.pl?mdl=SVE1712BCXB&template_id=1&region_id=1&tab=download# /downloadTab
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
If that does not work please take a look to the following link:
/message/231687 https://communities.intel.com/message/231687
