Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
RTX 2060 Not working with Intel DZ68BC
Jay22
I have Intel DZ68BC Motherboard with intel 2600K processor installed.
I recently purchased RTX 2060 graphic card for my system.
After Installing the graphic card to the board, system freeze at the post !! i am not able to see option to get into Bios.
I tried running the system without graphic card it works fine.
My bios is updated till 4.0
Please help !!
Thanks & regards
Jay
AlHill
There is no 4.0 bios.
There is bios 0042, which I have attached.
And, you are trying to run a 2020 video card on a 2011 board.  It is very likely a compatibility problem.  You might get lucky and find some current card that will work.  It is more likely that you can find an older nvidia g6x 750 of gtx 1060 card that will work.
n_scott_pearson
Super User Retired Employee
Make sure you are enabling UEFI Boot.
