Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
Re: DZ77RE-75K show only 4GB memory
AScot
New Contributor II
I do not believe 3x4GB is a supported configuration for the DZ77RE-75K.
Your board supports (1 DIMM) in slot 1 or slot 3.
Your board supports (2 DIMMS, or 4 DIMMS) in Slots 1+2, or 1+2+3+4.
So I recommend adding a 4th 4GB DIMM, or remove one of the existing 3 DIMMs and move the remaining 2x4GB into slots 1+2.
See the diagram below for slot locations/numbers.
http://downloadmirror.intel.com/21240/eng/DZ77RE-75K_IntegrationGuide02.pdf http://downloadmirror.intel.com/21240/eng/DZ77RE-75K_IntegrationGuide02.pdf
hatta
can this mother board support 8GB 2400MHz
i want to get this ram CMY16GX3M2A2400C11R
is it supported
AScot
New Contributor II
Memory specifications can be found here:
http://www.intel.com/support/motherboards/desktop/dz77re-75k/sb/CS-033457.htm Intel� Desktop Board DZ77RE-75K System memory
For guaranteed compatibility, I recommend going with something that is on the "Tested" list.
The specifications for the Corsair Ram you mention (CMY16GX3M2A2400C11R) says it is 1.65V, yet the DZ77RE-75K compatibility spec (linked above) states support only for 1.35v and 1.5v DIMMS. So I would hesitate to try the Corsair CMY16GX3M2A2400C11R modules with this board.
hatta
so does that mean it wont work on this board?
also can you link me to a module that 8GB 2400MHz that works with this board
this is frustrating
AScot
New Contributor II
I cannot provide a specific link to any 8GB 2400Mhz known to work, because the only data I have available is the list of what Intel has tested/verified with the board -- and there are no 8GB 2400Mhz DIMMs on that list.
For reference, here is another link to the specifications and tested DIMM list.
Any DIMM which meets the specifications shown near the top of that page under "System memory features" *should* work. I can only verify that the DIMMs in the "Tested" list are stated by Intel to be compatible.
Hopefully some other DZ77RE-75K users will see this thread, and perhaps one of them has tested/verified a particular 8GB 2400Mhz DIMM and will be able to recommend it to you. Otherwise, you would need to work with your memory vendor to find one that meets the specification, then perform your own testing/verification of that particular DIMM.
hatta
this motherboard sucks totally i shouldn't buy it in the first place
AScot
New Contributor II
I can neither confirm nor deny your assertion, as I don't have a DZ77RE-75K.
I have a DZ68BC, which is running pretty well with a i7-2600k. But I am very disappointed that all the BIOS releases beyond 0029 have generated lots of user complaints, and as a result feel "cheated" because I can't get the full capability promised for the DZ68BC without those later (and problematic) BIOS versions.
So I feel your pain, and Intel will not be at the top of my list for my next motherboard purchase.
hatta
absolutely right, i shoulda listen to my friend when he said to get Asus motherboard not this crappy board
thanks for the help
