Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
Rear fan PWM not working dh55hc
RPand2
I am having a PWM 4 pin fan to which i had connected to the motherboard rear fan header i.e air outlet fan
Before today i was able to control the speeds of the fan using bios or by using speed-fan but today i am not able to control the speeds neither by bios nor by speed-fan. Changed the fan also still nothing speed of the fan remains at its lowest speed which is 800 rpm or whatever the lowest speed of fan is. I used this fan with the front fan header and pwm was working but with rear fan header from today it is not working.
Is my motherboard rear pwm function went bad??
i had also not changed any setting in my computer which might cause this problem.
My motherboard is out of warranty.
Silvia_L_Intel1
Hello Rprathin, this kind of behavior could be expected after a BIOS updated or if could be a defective fan.
  • Since you already tested another fan and the behavior persisted, you may want to try removing the CMOS battery and disconnect the power supply from the board. Leave the system without any kind of power of about an hour. Then put it back in and restart the system.
  • You can also try running default BIOS settings pressing the "F9" key.
  • Finally, check which is the current BIOS version installed on the board and please let me know. I'll check if the BIOS need to be updated or not.
