Intel® Desktop Boards
Peer-to-peer support only
11477 Discussions
Removing custom bios splashscreen from DQ57TM
PHarv
Hi all,
I have inherited a DQ57TM board and processor and want to use it in a system I am making for a friend.
However the board used to be in another system and the manufacturer has installed a custom bios splashscreen that is displayed on power on. I Ideally want to remove this.
I have found out how to install my own splashscreen using the Integrator's toolkit, but Ideally I'd like to restore the default Intel spalshscreen.
All the instructions that I have found for doing this seem to relate to much older boards, and don't seem to work with this one.
Can someone tell me how to restore the default splashscreen please?
Cheers.
Phill.
n_scott_pearson
Super User Retired Employee
There's really no way to restore the default; once it is overwritten it is gone. You can use ITK to install a replacement image. You could, for example, grab and use one of the Intel logo images that is available on the internet (see Google Images or Wikipedia, for example)...
n_scott_pearson
Answering your other question, download and install the latest version of ITK (v5.0.4.575).
Within ITK, if you attempt to edit a BIO file that uses the older format (like that for DQ57TM), it will automatically switch to the old version of ITK.
In the old version of ITK, you click on Flex Modules and then right click on the logo entry (usually DPSD Logo) and select Edit Module. In the Customize BIOS Splash Screen dialog, click on File then Open Graphics File and then use the file selection dialog to select the file you want. Next, click on File then Update BIOS File to save the file and then on File and Exit to return to the ITK GUI. You can then click on Continue and then Finish to have the updated BIO and EBU .EXE files generated.
Hope this helps,
...Scott
