Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
Replace CPU fan on board
AHanc3
I'm trying to find a part number.
My desktop was dropped, and the CPU fan broke off of the mount.
I need to replace the fan.
Where is the best place to find which part would be compatible?
The board is AA G28805-402.
Thanks in advance!
Amber
AlHill
Provide the processor model number. Then we can identify the socket. Knowing the socket, you can search for a fan that will fit that socket.
Doc
n_scott_pearson
Super User Retired Employee
That's a DX79SI board, but that doesn't help us. Please provide processor model.
AHanc3
Thanks Al,
The processor isIntel Core i7-3820 CPU @3.60GHz
Is this enough info?
Cheers,
Amber
AlHill
This is your processor: https://ark.intel.com/products/63698/Intel-Core-i7-3820-Processor-10M-Cache-up-to-3_80-GHz Intel® Core™ i7-3820 Processor (10M Cache, up to 3.80 GHz) Product Specifications
You will notice that it has socket 2011.
A quick search reveals these two fans, although there are a large number of fans that work for socket 2011.
Shockingly, these two fans appear to be identical:
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=fan+fo... fan for i7-3820 - Newegg.com
Seems a bit pricey.
In this list of 23 fans that are socket 2011 compatible, the price varies widely:
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100008000%20601300413%20600035298&IsNod... Fan & Heatsinks, LGA 2011, CPU Fans & Heatsinks, Fans & PC Cooling, Components - Newegg.com
Since Scott knows this motherboard and socket much better than I, we should wait for him to chime in. He is on travel and may take a bit to respond.
The links are provided only for your convenience.
Doc
AHanc3
Thanks!!
I didn't hear back from Scott.
I want to go ahead and order a new fan.
If I find a CPU fan for a 2011 Socket - this will fit?
Cheers,
Amber
n_scott_pearson
A lot of these fans on the NewEgg page are designed for rack-mount 1U/2U workstation boards and will not work on the DX79SI board. Here is a sampling of some that I think should be ok:
https://www.newegg.com/Product/Product.aspx?Item=N82E16835119157 EVERCOOL NI2011E-9525EP 95mm Sleeve CPU Cooler
https://www.newegg.com/Product/Product.aspx?Item=N82E16835114127 Dynatron R9 77mm 2 Ball CPU Cooler
https://www.newegg.com/Product/Product.aspx?Item=09Z-01ZD-00002 Enermax ETS-T40F
https://www.newegg.com/Product/Product.aspx?Item=9SIA9PV3Y62105 Noctua NH-D14 SE2011 140mm and 120mm SSO CPU Cooler
https://www.newegg.com/Product/Product.aspx?Item=9SIA4RE4A21385&cm_re=intel_2011_heatsink-_-35-856-0... DEEPCOOL GAMMAXX 400-CPU Cooler 4 Heatpipes 120mm PWM Fan with Blue LED Easy installation
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=intel_2011_heatsink-_-35-103-... Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
