Hallo!
Does anyone know what pci-e version is on the s5000pal motherboard? I cant find anything about the pci-e specs of this motherboard. Only the fact it is on the motherboard.
Can anyone help me?
Thank you
The 5000 Series MCH used on these boards provides PCIe support compliant with the PCI Express Interface Specification version 1.0a. The raw bit-rate per bit lane is 2.5 Gb/s. This results in a real bandwidth per bit lane of 250 MB/s (given the 8/10 encoding used to transmit data across this interface). A PCIe port provides four bidirectional bit lanes and is referred to as a x4 port. The maximum theoretical realized bandwidth for a x4 PCIe port is 1 GB/s in each direction.
Hello:
Thank you Scott for the always useful and correct information provided about Onemanarmy's inquiry.
Esteban C
