I searched for this solution for a long time and I thought I would share it.
I have not had good luck with the Intel Atom Motherboards using a single vga display. Because of this I have been stuck on Fedora 14 i686 because of video problems. I use ELO 1280x1024 touchscreens for my embedded systems.
Let me explain the issue. The G3650 chipset has 4 displays and all of them are found when starting fedora 17 live and the LVDS-1 is detected as connected even if the bios says it is disabled. So here is the 4 steps for getting the install to work.
1. hit TAB and edit the startup command on the live iso and add:
video=LVDS-1:d video=DVI-D-1:d video=DVI-D-2:d
Complete the setup.
2. On the reboot, type e and edit the linux command adding the same paramaters.
3. After the boot install grub2-tools.
4. edit /etc/default/grub and add the parameters to the linux parameters and run grub2-mkconfig -o /boot/grub2/crub.cfg
This should solve the problems of running fedora 15 /16 /17 any live installer.
This will probably work with D525MW D2700MUD and most of the others.
I hope this helps someone.
We are glad to hear you were able to resolve the issue. Thank you for your feedback.
Thank you Sherman,
Also work on DN2800MT and D525MW with Fedora 17 full dvd install.
For these mainboards just need only ' video=LVDS-1:d ' parameter.
Bye
