Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
Secure Boot logo test WHCK failed on DH77EB
EPien
We have runing Windows 8 vertification tests on Intel Desktop Board DH77EB.
We get a problem to pass 'Secure boot logo test', we got an error:
Error7.12.2013 12:46:55.668 AreNotEqual(0, 0) - After ExitBootServices(), attempting to call GetVariable() on an existing variable with attributes "NV,BS" should fail. WexContextVerifyFile: Need_SymbolsLine: 0Error Type: Error Code: 0x0Error Text: Error 0x00000000End Test7.12.2013 12:46:54.168 Microsoft.UefiSecureBootLogo.Tests.VerifyBootServicesVariableBehaviorResult: Fail
We have try to upgrade to newest bios, so some have told, that might be a bios bug. But all the time we get this error.
In powershell by cmdlet - 'confirm-securebootuefi' result is True, spo secure boot is enabled and should work.
Depending on 10/18/2012 Intel Desktop/Motherboard WHC Report, there is no information about Errata or Contingencies, that this test should fail, or isn't possible to pass.
Is there some Ideas what to do in this case?
Silvia_L_Intel1
Edgar,
Based on the following document, you board qualified WHCK.
http://www.intel.com/support/motherboards/desktop/sb/CS-025834.htm?wapkw=desktop+whck http://www.intel.com/support/motherboards/desktop/sb/CS-025834.htm?wapkw=desktop+whck
Since you continue having problems even though you already installed the latest BIOS version on your system, there is a WHCK "reseller" program where you can submit the configuration to Microsoft and claim Intel's already submitted the motherboard certification.
http://www.intel.com/support/motherboards/desktop/sb/CS-031493.htm?wapkw=whql+reseller http://www.intel.com/support/motherboards/desktop/sb/CS-031493.htm?wapkw=whql+reseller
Regards.
Silvia_L_Intel1
Edgar,
Regards.
