Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
Serial port issue
AC0110
Serial port has suddeny stopped working in the rocketlake board. got serial logs three or four times, after that it just stopped.
is the understanding correct that there are 3 uart controllers on the board? and uart 2 is configured to be the debug port? if some problem with the uart 2 then can we change it to uart 0/1?
Or how can I get the serial logs back again working. thanks a lot!!
