Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Set supervisor password on hundreds of motherboards
MFrap1
ordI recently discovered the Intel Integrator Toolkit which is a great tool to allow us to configure all of our motherboards at the same time through the network.
The issue we are running into now is we would like to set a supervisor password on all of our motherboards and it seems that only our newer model of motherboard allows us to do this with ITK. the previous model with use ITK 4.0 do not have an option to set supervisor password.
Is there another way we can set a supervisor password with visit every machine manually?
Silvia_L_Intel1
Tmen, the Intel® Integrator Toolkit (ITK) will allow you to create an image so you can install it on the systems, however the supervisor password option is only for you to enable or disable a setting. In order to created and set a hard drive or a supervisor password, you will need to access each board individually.
