Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
Software & Drivers update
Arthur11
i download and install Need For Speed Heat,when I try to run it ,it say my driver version is old,and the recommended driver is xx.xx.15.4251,i try to search the website that it give and update my driver.
After update,i'm restart my laptop and try to start the Need For Speed Heat,but it still tell me to update my driver to xx.xx.15.4251 althought that i'm already update the new driver,please help me,thanks
n_scott_pearson
Super User Retired Employee
First of all, this is telling you the minimum version that you need for the game. In almost all cases, there are newer versions that are even better.
The problem is that the xx.xx is the important part for discovering what driver download you need. Please download and run the Intel System Support Utility for Windows and have it save the report to a file. Then, come here and click on Reply to start a response message. Then, upload and attach this file using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response.
....S
