Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Swapping SATA inputs between SSD drives on Intel Desktop Board DZ68DB
SRuba2
Hello.
I have a pretty old board model (Intel Desktop Board DZ68DB). This board originally had 2 drives, SSD and HDD, both connected to the SATAIII (6GB) ports ("blue" ports) on my board. The SSD had the Win7 OS installed, and the HDD had some data.
I have added 2 more SSD drives to my board, and connected them to the available SATA ports. I have installed Win10 OS on one of them, and I currently have a dual boot pc and everything works fine.
Little did I know, the new SSD drives were connected to the SATAII (3GB) inputs, while the old ones (which are not even SATAII compatible..) are connected to the only two SATAIII ones.
Now, I want to swap between the old and the new drives so I can actually take advantages of the SATAIII performance. But! When I tried to do so, I couldn't boot up with any of them.
My question is, Is there a special case where the drive contain the OS, therefore the board will not "accept" the port swap? AFAIK, the SATA inputs are for data only. 😮
Shay.
AlHill
Start bangling on F10 when you boot your system. You should see a boot menu.
Doc
n_scott_pearson
Super User Retired Employee
Since you are using both SATA connector types, the drivers are all loaded and can support drives on either. Having drives move from one port to another should be automatically handled -- but you might have to make changes in the Boot Order list in BIOS Setup. As Al indicated, you can verify that you can still boot after moving the drives around by pressing F10 and selecting the drive you want to boot from. After verifying that it works, yu can then go into BIOS Setup and change the Boot Order to reflect the driver movement.
Now, where you might run into a problem is in your dual-boot support. You may also have to make changes in the GRUB configuration and/or Windows config file after moving the drives around.
Hope this helps,
