Intel® Desktop Boards
Peer-to-peer support only
TZ00 temp
GTitc
Hi I have just built a new PC and getting BSoD, I have discovered by using "Speccy" and "CPUID" that TZ00 is running at 122c I'm sure this is not good.
Is this a faulty MOBO or is there something I can do to remedy this?
System
Motherboard: Asus H81M-K Intel H81 (Socket 1150) DDR3 Micro ATX Motherboard
CPU: Intel Core i3-4330 3.50GHz (Haswell) Socket LGA1150 Processor
Memory: TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit
GPU: 1GB MSI GTX 750 OC Armor Fan
OS: Windows 8.1
Allan_J_Intel1
Thanks for joining the Chipset community.
You can get a temperature range 90 °C to 120 °C. 90 °C to 120 °C for the Intel H81 chipset.
https://www-ssl.intel.com/content/www/us/en/chipsets/8-series-chipset-pch-datasheet.html Intel® 8/C220 Series Chipset Platform Controller Hub: Datasheet
As per processor temperature 66.8°C
http://ark.intel.com/products/77769/Intel-Core-i3-4330-Processor-4M-Cache-3_50-GHz?q=%20Core%20i3-43... ARK | Intel® Core™ i3-4330 Processor (4M Cache, 3.50 GHz)
I recommend checking the link below for more information about overheating:
http://www.intel.com/support/processors/sb/cs-029426.htm Processors — How do I know if my computer is overheating?
Allan.
