Community
cancel
Showing results for
Search instead for
Did you mean:
MHock1
The 4 CPU fan hold-downs on an Intel FC-4GA4 CPU
I have turned the 4 CPU fan hold-downs on a Intel FC-4GA4 CPU assembly, so they are now loose, but they still hold the fan down -- it only lifts up about 8 mm, but which I think means that the heatsink compound is not holding it down. Please can anyone advise how to lift the fan assembly off, so that I can replace the CPU?
Tags (1)
IUman
Hello mgh,
Thank you for joining the Intel communities.
Please take a look to the following link, it will show you how to remove the heat sink.
https://www.youtube.com/watch?v=AegVBU_fo-8 https://www.youtube.com/watch?v=AegVBU_fo-8
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan
MHock1
Thanks very much -- info greatly appreciated.
mgh
IUman
You're very welcome and I'm glad to hear that the information I provided is useful for you.
Best wishes!
Ivan
