Community
cancel
Showing results for
Search instead for
Did you mean:
yka_c
The DQ57TM will Hang when saveing the BIOS
i am using a MB DQ57TM with i5-650 (the BIOS ver. 0050)
after i entered the BIOS and exit, i use "Exit Saving Changes" to save the settings
but it will hang and no response.
i tried to load the default setting, clear the bios but it still have the problem.
i remember that before the 0050 bios, i can save the setting without any problem.
it will shutdown and power on again.
should i restore the old BIOS?
thanks
Community Manager
Hello Yip,
Our recommendation is trying a BIOS recovery update to either version 0050 or a previous one. If you determine the issue is associated to the 0050 version test with a previous one indeed.
BIOS versions can be downloaded from the following web site:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=... Download Center
Please be sure to read and follow all accompanying instructions, which can be found at this link:
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS update instructions
