Well, it seams that I have got this again! I cannot access the BIOS with F2 or any other way! Nor can I access the Boot Menu! I was able to re-flash the bios (650) back to (650)
I had this problem before for like 2 days I don't know what I did to fix it, but it was running really slow and almost all the memory was reserved! Then on a reboot it was just fine/!?!!?!?!??!!?
I could not access the BIOS with F2 or the Boot Menu with F10. The Bios jumper doesn't do anything ( but did work when I took it all the way out. and continuously hit the F7
with flash drive attached! and I re-flashed the same bios hoping that the NVram would clear. ha the battery out even and it updated! after it said reboot I put jumper back and the battery back
still the same :-( I am on my 4th day of no computer. I have done all of the recommendations such as remove all but one piece of Ram, took sound card out, reseated the video card
So please can somebody give Me a little help or advise? Thank You in advance!
Machine Specs: DX79TO Motherboard with current (650) bios
I7 3820 Cpu running at 3.6 Hhz.
Corsair x90 CPU Watercooler
32 GB Corsair "Vengeance' DDR 1866 10-11-10-30 running at XMP 1866 Mhz.
MSI 960 GTX 4gb
Sound Blaster SB5100 X-Fi pci-e x1
Corsair 60 GB SSD
2 X Western Digital sata HD 1 TB each
Seagate Barracuda sata 2TB
ASUS dvdR Burner
Razer Black widow Ultimate edition
Razer Death Adder 3500dpi
Operation Sys: Windows 10 Pro
Various Linux Distros. (Mageia 6.0) at the moment.
Hello DaneBurdick ,
Thank you for contacting Intel Communities.
I am sorry to hear you are having issues to access the BIOS on your Intel® Desktop Board. Can you please provide the following information to better assist you?
I hope to hear from you soon.
Juan V.
Juan,
No freezes that I can tell?
And no wireless Peripherals (they are all in machine spec's!
and the biggey, It will not POST nor boot at all!!!!
and how do You know that I go by "Dane" and I also go by "Burdick" My Birthname!
Hello DaneBurdick,
Can you please remove all memory sticks and let me know if you hear 3 beeps?
If you hear 3 beeps, it means that the processor is being detected by the motherboard and the problem might be related to the memory slots on the board or to the memory sticks.
As for the name, it is how the system recognizes you as a user.
Juan V.
Ok done that, 3 beeps! I even took all but one stick out to try it but was a no go!
I just won a bid on E-Bay on a identical motherboard , should be here Monday or Tuesday?
If the same thing happens with the "new" board, I would look at there being a failure in the memory...
Hi DaneBurdick,
Thank you for letting me know. I will be awaiting the results.
Juan V.
OK Juan, Thank You for the help!
well 2 of the sticks are only a couple of months old!
Hey, I have had memory fail fresh out of the package. Failing after a month or two is not out of the realm of possibilities...
Hi DaneBurdick,
I was reviewing this thread and I wanted to know if the replacement board fixed the issue?
Juan V.
This new Mother Board is doing the same damn thing! I took out all the ram and only put in one stick!
b2b, jumper pin, F2,F7,F10, all fail it just keeps booting what ever is there!
with the last mobo My main disk wouldn't boot the BCD was corrupted or something
now at least I can boot to windows but it show 29.0 GB assigned to "Hardware Reserved"
and only 3 GB available !
Dana,
On the back panel of your board, at the far left, there is a "Back-to-BIOS" button. With the system powered off, engage this button. When you power on, this button should light up and the system should automatically enter BIOS Setup (i.e., no F2 necessary). Once there, use F9 (followed by 'Y') to load the default BIOS configuration over the current. This should remove this strange memory configuration. You can then make any changes to the configuration (boot order, etc.) that you absolutely need. Then, use F10 (followed by 'Y') to exit from BIOS Setup with a save of the current configuration.
Hope this helps,
That doesn't work with board! This is My second one, but I have found a solution
In a Windows Admin Command Prompt type "shutdown -s" and it doesn't go into hybrid S mode and then ir magically works!
What doesn't work? Please be more specific.
