Hi All,
I am planning to build a AlO PC with thin mini-itx motherboard (either with DH61AG or DQ77KB) having 32" or 42" LCD panel. Are there any chassis which can be used off the shelf?
Any advice is appreciated.
Aziz Jiwani
Our recommendation is checking the Mini-ITX component catalog list which can be found at the following website:
http://download.intel.com/support/motherboards/desktop/sb/thinminiitxcomponentcatalog.pdf http://download.intel.com/support/motherboards/desktop/sb/thinminiitxcomponentcatalog.pdf
HI Dan,
Thank you for your reply.
I have gone through the catalog, none of vendors are providing screen size more than 24". If you are aware of it then can you please suggest me.
Aziz Jiwani
I am interested in smaller screen sizes 12" to 16" for touch screen AIO on a monitor arm.
Dan_Intel, is there an Intel engineer I can talk to about screens that you know are compatible because they are being used by OEMs in a laptop, IPC or similar?
I recently saw some information on a display for Thin MITX. Might try looking at Youtube for Thin Mini ITX DIY All-in-One PC or go to the Gigayte B2B Website. For some reason it is in that area on their Website. I hope this helps a little.
http://www.youtube.com/watch?v=eNL6DuBtFNg Build Your Own DIY All-in-One PC with GIGABYTE Thin Mini-ITX - YouTube
